Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I need some help with installing a 2 person self contained hot tub. The unit will be sitting very close to the house and there is not much space. I have attached a photo. The hot tub will sit in the area where you see the ice chest. The hot tub will be installed on a gravel base. There are brick pavers surrounding the area. I intend to move the A/C disconnect to a new location away from the hot tub. I would like to run RNMC along the wall of the house and ON the ground to the GFCI disconnect for the hot tub. I would also like to run the A/C power on the ground in RNMC. 680.10 prohibits underground wiring with 5 feet horizontally unless installed in race way and buried. Does 680.10 prohibit using a raceway on top of the ground? Finally, I understand I will need to bond the vents, window frame and water pipe together. Finally, does 680.26, equipotential bonding, require that I install a grid in the gravel base and extend it 3 feet horizontally?
I apologize for these questions but I don't have a lot experience with 680.
