eventhorizons
- Barstow, CA USA
Customer's existing setup consists of a 200A 3-phase Service meter with a 200A fused disconnect immediately adjacent to it. From the disconnect, it penetrates the building and goes to a 200A panel with a main breaker. 4/0 wire for all.
We are installing a solar array on the roof that will supply a peak of 42A. The original intention was to use the "10-foot Feeder tap rule" and tap between the outside fuses and the inside breaker, installing a 100A disconnect with 60A fuses. All panels are immediately next to each other.
Meter <----> 200A Fused Disconnect <----Tap----> 200A MB panel
Tap <--------> 60A-fused source
The county plan-checker rejected that idea, saying that 690.64(B)(2) applied here. This required changing the plan such that we would instead add a 200A panel and run 4/0 wire, making it a "splice" instead of a "tap" and also downsizing the main meter source to 175A. The customer does not need the full 200A service, so this is not a problem for him.
Question: Is the checker applying the code correctly? Based on my detail reading, especially the articles by John Wiles, I feel that he is. But this is one of the situations that begs for an exception, since the INTENT of the rule is to prevent overload of the conductors/bus due to multiple sources. In this case, there is no way that the current in the conductors can exceed 200A.
Thanks in advance for your feedback.
Ken
Ken
