Or Class 2 or 3 wiring specifically rated for concealed use. And/or plenum rated if in a ceiling space used for environmental air.You might also want to look at 640.8(C). Basically you follow the same rules as any power supply. The required wiring method will be marked on the rear of the amp near the output. Class 2, Class 3 or Class 1. Class 1 requires a Chapter 3 wiring method, CL2 and 3 can be any cable with that listing run exposed.
-Hal
No, the statement was that essentially all wiring that is rated for Class 2 is rated for concealed use. Unconcealed use is also allowed, not necessarily even protected from damage.Just got my LV license so learning, so dont mind the repeated question and I am having a hard time understanding what is meant in this thread.
The amp we are looking at is class 2 and the runs will be in a retail store with open ceilings. the speakers will be mounted to the beams.
Are we saying that all class 2 wiring is classified as concealed, and that if it is running in an open ceiling it needs to be in conduit?
Guess I better pull my code book out...:slaphead:
