- Bremerton, Washington
- Master Electrician
700.3(F), new to the 2017 NEC requires temp source of power if the emergency system is out of service
(F) Temporary Source of Power for Maintenance or Repair of the Alternate Source of Power. If the emergency system relies
on a single alternate source of power, which will be disabled for maintenance or repair, the emergency system shall include
permanent switching means to connect a portable or temporary alternate source of power, which shall be available for the
duration of the maintenance or repair. The permanent switching means to connect a portable or temporary alternate source
of power shall comply with the following:
Does this requirement apply to all 700 emergency systems, or just those installed after the 2017 NEC is in effect for the user?
