705.21(D)(1) requires that a dedicated circuit breaker or fusible disconnect be required on the output of a PV inverter. The article does not say however where this device shall be located. If there is a breaker being used to tie the PV inverter into the main panel does this satisfy this requirement? What if the breaker located at the panel is 50ft from the inverter?
Do we have to follow the tap rule here and adhere to the 10ft or 25ft rule?
