I have not had any formal 70E training.
It is a step that I will take.
I think that you have given me enough of an answer to my question in the original post. I should be wearing arc rated PPE to connect a load side wire when the line side is live. Can you give me a reference that I can look over, and to present to our safety rep.
Thanks for the help.
Rich
I think you are missing the point, the NFPA 70E is not a guide to working on energized equipment, in fact one of the very first statements in the standard requires nealy all work to be done in an electrically safe working condition.
NFPA 70E Article 130.1 Justification for work. Live parts to which an employee might be exposed shall be put into an electrically safe work condition before an employee works on or near them, unless the employer can demonstrate that deenergizing introduces additional or increased hazards or is infeasible due to equipment design or operational limitations.
Energized parts that operate at less than 50 volts to ground are not required to be deenergized if there will be no increased exposure to electrical burns or to explosion due to electric arcs.
NOTE 1: Examples of increased or additional hazards include, but are not limited to, interruption of life support equipment, deactivation of emergency alarm systems, shutdown of hazardous location ventilation equipment
NOTE 2: Examples of work that may be performed on or near exposed energized electrical conductors or circuit parts because of infeasibility due to equipment design or operational limitations include performing diagnostics and testing (e.g., start-up or troubleshooting) of electric circuits that can only be performed with the circuit energized and work on circuits that form an integral part of a continuous process that would otherwise need to be completely shut down in order to permit work on one circuit or piece of equipment.
(Zog's note: If you dont know what "Infeasible" means, look it up; it means "incapable of being done". Dont confuse feasible with convenient.)
70E training is not optional, it is required, that is what you need to be telling your safety rep.
