Does underground duct banks get labeled during in arc flash survey ? Where would these labels be placed since there really isn't anywhere to place them ? People do enter these for repairs or inspections so this is a great way to make sure they enter when safe .
The reason being is in the pass the cables have been below water , the feeders are exposed and to me are a hazard. The cables have burned apart and have been repaired a couple of times before. I believe if a worker has to go below he should know the hazards before hand. Deenergize. Multible 600-800amp 480 volt feeders.If you are
surrouned by energized cables thats a hazard.
The labeling is the minimum required. The owner can always post the arc flash level for the various conductors in a handhole or vault; even if there is no operable equipment. The owner can also post requirements for vault entry that exceed OSHA hazardous entry permit levels. The owner can post as many "DANGER" signs as they want. (Not that anyone reads them!)
