transman2
- Brooklet,Ga.
If I install a feeder for a sub panel with 500 AWG THHN wire (380 amps) using the 75 C allowable ampacities chart on 310.15(B)(16) and due to the fact that the breaker manufacture termination lugs are only rated at 75 degrees and following 110.14 (C),(a)(b). However 240.4 (B) says I am permitted to go the next higher standard overcurrent device rating which would be 400 amps. Is this a conflict?? Not sure how to rule on this and hope I can get some help. Thanks!!
