What would the ampere rating be for 750kcmil THHN/THWN-2 at 35°c ambient?
Would you use the 90°c rating of 535amps (TABLE 310.15(B)(16)) multiplied by 0.96 (TABLE 310.15(B)(2)(a)) 90° column.
Using this method I come up with an ampacity of 513.6 amps.
Then using the 75°c column I can use the ampacity of 475 amps for the terminations.
Is this correct?
Is this correct?
