8 ft LED tubes with high output pins
jaylectricity
Massachusetts
licensed journeyman electrician
Hey all, hope things are going well.
I am looking for 8 ft LED tubes dual-end feed 120v with the high output pins.
I found these, which look like what I need, but it's a 10 pack and I only need four.
I thought it would be helpful to know if there is a name for the high output pins that I can add to my search.
Or, you know, if you have an amazon link to what I'm looking for, that would be great.
I'd also accept tried and true websites, but I'm weary of buying stuff online unless I know they're reliable.
Thanks...I'll check in periodically. No immediate rush, but I'd like to get them ordered soon.
curt swartz
Electrical Contractor - San Jose, CA
San Jose, CA
Instead of depending on random retail web sites why don't you talk to your local supply houses? They should have in stock or easily be able to get you the lamps.
brantmacga
Señor Member
Georgia
Former Child
I’ve been using Keystone for LED HO tubes if it’s an easily accessible location.
I’ve also used Phillips brand HO sign lighters because they’re available with a remote driver; that’s ideal on signs where it can’t be reached from the bucket truck. You can mount the drivers in an enclosure in an accessible location.
