dave5567
New User
- Toronto Canada
I have a question regarding Branch Circuit O/C Protection as defined in the NEC, Article 210.20 Overcurrent Protection.
As per 210.20 (A) : If I have a branch circuit supplying a continuous load, I must ensure that the circuit breaker protecting that branch circuit has a rating not less than 125% of the continuous load.
Exception: If the entire assembly, including the breaker, is rated for 15A continuous, then I must ensure that the circuit breaker protecting that branch circuit has a rating not less than 100% of the continuous load.
What I am confused about is the following :
If I have a 15A circuit breaker rated for 80% this means it can handle 12A of current flowing continuously.
But by 210.20 (A) I must ensure that the rating of my breaker is not less than 125% of my continuous load.
Hence, by 210.20 (A) the maximum load I should design for seems to be 12A/125% = 9.6A max since its a 15A breaker (15A trip) but it's only 80% rated (12A).
This doesn't seem logical to me but I want to get the opinion of someone who is more familiar with O/C sizing in the USA.
Thank you,
Thank you,
