iggy2
- NEw England
from the Mike Holt site, for reference (citations may be out of date):
MY QUESTION IS - what is the circuit required for (3) plasma displays, at 703 VA each, assuming they are continuous (3+ hours) loads? (commercial application)
3 x 703 = 2,109 VA. I would say this exceeds 80% of a 20 ampere CB, so cannot go on a 20 ampere CB. But, table 210.24 shows "maximum load" for a 20 ampere receptacle circuit to be "20 A" with no reference to 80%. Can I show (3) receptacles on a 20A branch circuit to feed these three displays??? 220.14(A) says I need to use the load of the appliance served - so I cannot use 180 VA.
As always, Thanks.
Q. What is the maximum number of duplex receptacles on a two-wire 20 ampere circuit?
Section 220-3(c)(6). The NEC does not have a specific rule that says 10 receptacles on a 15 ampere circuit or 13 receptacles on a 20 ampere circuit. For 15 ampere circuits, the calculation is as follows: 120 volts x 15 amperes = 1800 VA/180 VA = 10 receptacles, and for 20 ampere circuits, 120 volts x 20 amperes = 2400 VA/180 VA = 13 receptacles.
Many people think that when calculating the number of receptacles the load should be reduced by 80%, but this is not the case! Yes, the NEC limits the load on receptacle circuits to 80% for portable appliances [210-23(a)] and, yes, the maximum continuous load on a branch circuit shall not exceed 80% of the circuit rating (protection device) [220-3(a) and 384-16(c)], but these rules don't apply to the number of receptacles per circuit. I wish the NEC were more specific, but it's not.
As always, Thanks.
