Our local utility has a rule that all 320 Amp services require an 80% rated circuit breaker as the Main Overcurrent Protection.
I'm pretty sure most molded case breakers are 80% rated, but I'm having trouble finding any documentation.
Just using Square D for example, the L series breakers are available as either electronic trip, or thermal magnetic. The electronic version is available as either 80% Rated or 100% Rated, and I'm assuming the 100% rated would be more expensive, and less common.
But the thermal magnetic trip L series don't specify if they are 80% or 100% rated.
I believe there is also a 400A frame Q4 breaker for NQ panel mains. It doesn't specify if its 80% rated either.
One other question - Do 80% rated breakers actually have a lower trip point??
Thanks
Thanks
