80%verses100%
travis3710
Virginia
I here alot of electricians say you can only place 80%load on the rating of breaker.If the load is non continuous then the load can be at 100% I think.Continuous being 3 hours or more.
roger
Fl
Retired Electrician
Re: 80%verses100%
Travis,
you are correct.
Roger
templdl
Wisconsin
Re: 80%verses100%
If the wire is sized properly and the breaker sized to protect the wire this, with almost all certainty, is not an issue.
Look at art 210.19 (A)(1) and 210.20(A)
GG
Ft.Worth, T.X.
Re: 80%verses100%
Wouldnt you have to consider 210.23(A)(1) & (2) or are you refering to a load that would not fall in the category of 210.23(A)(1) & (2)? Thanks.
iwire
Massachusetts
Re: 80%verses100%
210.23(A)(1) & (2) is only about the connected loads not the entire circuit.
210.23(A)(1) for example limits one cord and plug connected equipment to 80% of the branch circuit.
So on a 20 amp receptacle circuit you could plug a 16 amp heater in along with a 4 amp TV.
roger
Fl
Retired Electrician
Re: 80%verses100%
GG, the sections you reference would not change the branch circuit OCPD rules of noncontinuous verses continuous loads.
Roger
infinity
New Jersey
Journeyman Electrician
Re: 80%verses100%
This would only apply to a multi outlet circuit. A circuit with a single receptacle can be loaded up to 100% of its maximum rating. See 210.23
petersonra
Northern illinois
engineer
Re: 80%verses100%
[qb]
And just how would a HO know about this rule?
Besides, TVs are continuous loads, seeing as they are on for 3 or more hours continuously. Think super bowl sunday.
