800A outdoor panel with integral main meter
The panel is located outdoor by the parking lot, should it be better to have lockable panel with integral meter than external meter?
Does anyone know a 800A panel, 208V/3PH, 4W, NEMA-3R with sub-meter meter to record monthly kwh usage for billing and talk to BMS as well?
Saw this panel below from Eaton (Pow-R-Line PXBCM Panelboard ) may do the work but only rate at 600A max.
Glanced at the link And saw this:
"Service entrance panels combining a main
disconnect with a power company metering
compartment 400–1200 A"
I think you will just have to price out one of these pre-manufactured options, and then compare it to using your own separate metering equipment, such as one of those ekms and decide which is better for you.
Square D offers their “Smart Cell” units. They offer a basic Energy Meter , EM3555 or EM3560. Unit plugs on like an I-Line breaker
Square D offers their Smart Cell unit. Plugs on like an ILine breaker: offer three different meter platforms Basic Energy EM3500 series, Basic Power PM5563 and advanced Power PM-8244. https://download.schneider-electric...p_File_Name=NHA999570.pdf&p_Doc_Ref=NHA999570
+1 for the Sq D smart cell unit. I’ve installed them, but I have no experience with the software end. The breakers you want to monitor will need the Micrologic unit as well attached and wired to the smart cell. SqD will factory-build the setup for you and all that’s needed is to connect the smart cell to either Ethernet or serial communication.
