True, but from my experiences, owners or not so electrically qualified maintenance people are less likely to have real quick access to 600 or 800 amp fuses, or even 400 in many cases and someone qualified will be called upon. For 200 amp or less and particularly 250 volt fuses - those are available at most any local hardware store, and of course if it has a higher number on it and will fit - that is what gets used.
I also find these sort of people to be the ones likely to crank up an adjustable motor overload setting when it trips frequently. Which is why I still like melting alloy type overloads better then any type with easily adjustable dials - unless someone that knows better will be watching over them, then the electronic overloads do provide even better protection. Most are not going to change overload elements - though I have seen that done by non qualified people where the overloads were readily available to them. Then they ask you some time later why that motor burned out.
