SG-1
- Ware Shoals, South Carolina
I am looking for the code references for violations in the following scheme.
Background:
Two transformers are within either metal-enclosed or metal-clad medium voltage switchgear. They are contained in metal structures. The transformers are grounded using the switchgear ground bus, usually a 1/4 x 2 copper bar at the transformer.
The output is typically used for control power, lights & space heaters.
Issue:
Only the ungrounded conductors of the two separately derived transformers are being switched. The grounded conductor is not switched.
Background:
Issue:
