stonecitysub
- MidWest
Situation on hand; A relay panel in substation house was being cut to fit in a bigger relay with a sawz-all. The metal was not very hard and the sawz-all handled it with ease and not much vibration. Test switches were pulled on two of the three SEL 501 Over Current relays on the same panel. The lockout that rolled was about 3 feet away from where the cut was being made. The owners are claiming that the 86 tripped mechanically due to the vibration from the saw. Myself as well as some few engineers and other techs I've talked to think it is more likely that there is a loose wire or connection somewhere on the 86 that got wiggled and made/lost contact and that was the problem.
Has anyone seen a situation like this before? any other suggestions or other opinions? Thanks.
