Stevenfyeager
- United States, Indiana
- electrical contractor
a pole barn will be conditioned by a 90 amp electric heat pump, coupled with a 35 breaker outside unit. (the HVAC man tells me) A 125 anp sub panel would be a common breaker size and would suite the situation, location of both units and would equal the 90 + 35 exactly. Is that too close a match ? ( 80 feet of wire distance from main panel.) I asked the HVAC man if the 35 and 90 would ever be used simultaneously, he said yes, for some short term cycles.
Suggestions welcomed, thank you.
