Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
I am curious. I understand when running conduit the 360 degree rule, and you are supposed to run the pipe first and then pull the wires through. But, how do you deal with the 90 degree fittings for flexible conduit? You certainly can't pull wire through them, is it ok to pull the wire through the conduit before you attach the final 90 degree fitting? :?
