The Widget
- Seattle
- General Contractor
Afternoon, I have a shop that currently has a 30amp subpanel from the house 200A panel. I plan to upgrade to a 90A main breaker subpanel in the shop, with a 90A breaker in the main house panel. Part of the run will be SER in the house, then transition to URD underground direct bury to the shop, then transition again to SER at the shop. The run will be about 200 feet, likely less.
Is 2/2/2/4 SER AL cable on the interior areas and 2/2/2/4 URD underground adequate?
Thanks for the help!
