From previous threads started on this topic it has been determined that for each temperature increase there is an H in the symbolism (tw=60)(thw=75c)(thhn=90c)and in homes built before 90c wire was installed lets say Mr Dough wants a new light installed and the light says MUST USE 90c WIRE; now is that for the heat output by the bulbs or is it due to the draw there would be on the wire; If it is a heat thing then would additional insulation help or would a pigtail on a pc of 90c wire be sufficient; But if it a draw on the wire then would a rerun of the circuit be warranted (just for 1 lite?)
