Re: 9fixture of 60watt
I would have to agree with you, Charlie. It is impossible to control what will get done at some unknown future time so we can only use the information available at the time. This does lend support the idea that some method of proving competency such as licensing or tracking for inspection should be in place in order to even purchase electrical components. It's amazing how many co-workers, neighbors, friends, etc., get upset when I suggest they need to get their work inspected to be sure it's safe, even though all they maybe did was replace a broken light switch, receptacle, or other fixture. In Minnesota it is the law but it is nearly impossible to enforce on homeowners except for projects where permits are required. It is too easy and likely that improperly sized devices will be installed. When I bought my home, I discovered that the smallest fuse in my 60A service entrance was 30A rated. Except for the electric range, water heater, and electric dryer circuits, the largest wires used on any circuit was 14ga. I even found 100A fuses in the main disconnect supplying the home. To this day, I don't know how the house never caught fire. Needless to say, one of my first projects after replacing the fuses was to remodel the entire electrical system.
Bob
