Few if any people can tell the difference between a good quality sound system that is relatively inexpensive and the very expensive "high-end" units.Originally posted by luke warmwater:
I definately can tell if something sounds 'good' to me. Now that doesn't mean that I can tell if it is a low cost or high cost item.
Why are the runs long and extra long? Don't you run the speaker wire from the volume control that is pulled in CAT5e?? Unless your volume is far away from you speakers, but I wouldn't think it would be.One drawback of A-Bus is long to extra long speaker wire runs.
[/QB]
With the P$S system, you are supposed to run from the receiver to the distribution board, where there is a card for slitting off to different rooms. From the card, ou run to each volume control and then to the speakers.Originally posted by nicknorth:
Why are the runs long and extra long? Don't you run the speaker wire from the volume control that is pulled in CAT5e?? Unless your volume is far away from you speakers, but I wouldn't think it would be. [/QB]One drawback of A-Bus is long to extra long speaker wire runs.
What I said was "Few if any people can tell the difference between a good quality sound system that is relatively inexpensive and the very expensive "high-end" units.".Originally posted by luke warmwater:
But, am I mis-understanding you and Bob? Are you saying that you think most people can't tell if something sounds good or bad, or that most people can't tell high quality from low quality, or high price vs. low price?
As I said before, I can tell if something sounds 'good' or 'bad'. But that doesn't mean that the better sound didn't come from less expensive equipment.
Can you not tell if there is distortion in the low end? Or cracking in the high end?
