1793
- Louisville, Kentucky
- Inspector
I have been called a few times to do a panel change where the existing service does not have a main. The wire is has no legible writing so I cannot tell the wire size.
I have been doing a Load Calculation using an Excel sheet I found on this site. My question comes to sizing the A/C. In the Excel program it asks for the tonnage of the unit. When you enter 3 Ton it displays 4,700 VA, if you enter 4 Ton it shows 6,300 VA.
Does anyone know how the VA values were calculated?
If I were to use the nameplate on the unit would I use the Min. Circuit Ampacity or the Max. Circuit Ampacity X 240 for the VA?
I hope this makes sense to someone.
Edited for clarification of Max Circuit Ampacity.
