jango
Can a residential air conditioning compressor's disconnect be a small circuit breaker exterior panel box? I have a 4-3 romex feeding the area and I wanted to put a small 2-4 sub panel to also run some other small loads. The A/C is a 40A unit. Can a 2-pole breaker in the small sub panel be the means of disconnect for the A/C? Thanks in advance for your input.
