ceb58
- Raeford, NC
I have one I am not sure on and would like input. Wiring a small apartment above garage. Originally the air handler was to go in the attic space. Pulled wire for air handler and light and recp. Now for what ever reason the A/C contractor installed the air handler in a dormer cavity. The inside of this wall will be a bed room. They installed the AH so the access panel will be between the studs. The owner will have to install a access door in the wall to get to the AH. Now the question. With the access door open to service the AH You would be 10ft and with in site of the panel feeding the AH. Would installing a breaker lock on the breaker feeding it suffice for the disco? All so would the light in the bedroom suffice? There will be a recp. with in 3 ft of the access panel so this should cover the requried recp. The reason being the AH has filled up the cavity and has little or no room to install a seperate disco and light.
