Howdy folks!
I went to use my 6" Delta wood planer yesterday which usually stays dormant and unused. It had a heck of a time turning on this time and continued to trip either the 20Amp breaker at the panel or its own circuit breaker. I got it to turn on just once by rapidly turning the switch on and off. I investigated to possibility of both the blade drum and/or the motor getting hung up or sticky but neither was the case. With the belt off I tried to turn on the motor and noticed the motor trying to turn backwards!!! It would get a couple of revolutions in and then trip the breaker - very bizarre!!!
I fiddled with the switch for a few more minutes and then got a large spark and flash from the motor area under the tool - but it did not trip anything. Now the thing works perfectly every time - Weird huh? Whats up? I'm not asking you to fix this stuff - I'm just asking you to explain it.
