Re: a/c wire size
This is the letter I received from the state from the codes and standards department.
The AC states 22amp min circuit. max 30 amp ocpd. I installed a 12-2 nmc on 30amp breaker and the inspector said it did not comply.
Dear Mr Sperry:
This is in response to your letter dated January 23, 2003 concerning the selection of branch circuit conductor size feeding an air-conditioning unit. Based on the information submitted by you, I have the following comments:
The air-conditioning unit in question has a minimum circuit ampacity 22 amperes marked on the unit. This value is the required minimum ampacity of the branch circuit conductors selected from table 310-16 of the electrical sub code (NEC 1999). The table shows that a #12 awg typeTW, TWN, THWN copper conductors can safely carry 25 amperes continuously where operated in an ambient temperature not exceeding 86 degree F. Type NM cable size #12 AWG is in compliance with the electrical subcode as it can carry 25 amperes at 60 degree C. The footnotes that limit the overcurrent protection AWG sizes 14, 12, 10, do not apply in the case of motor circuits. The conductors in type NM cable are rated for 90 degree c. If no derating for ambient temperature is required, the electrical subcode does permit the installation of #12 AWG copper type NM cable feeding the motor compressor to have an overcurrent protection device rated at 30 amperes, the maximum permitted by the manufacturer of the unit.
The 30-ampere fuse or circuit breaker at the source of the circuit will protect the conductors against overcurrent due to short circuits and ground fault as stated in section 440-21 of the electrical subcode. The provisions of part C of article 440 are in addition to or amendatory of the provisions of article 240. The motor winding and circuit conductors are protected against overload relay device usually contained in the motor controller, which is set at 115% or 125% of the running current. The combination of above-mentioned two protection elements, in my opinion, provides the protection necessary for the safety of the hermetic motor compressor circuit.
Sincerely Yours,
Ashok K. Mehta
