A couple of layman questions
petereads
(1) Which voltage on an electric motor draws the higher amperage 380V or 220V?
(2) How should the overloads be set on a motor starter? Would it be 25% above nominal voltage rating adjusted for temperature?
mdshunk
Right here.
petereads said:
(1) Which voltage on an electric motor draws the higher amperage 380V or 220V? ?
An identical motor will draw less current (amperage) when connected at the higher voltage.
petereads said:
((2) How should the overloads be set on a motor starter? Would it be 25% above nominal voltage rating adjusted for temperature?
Overloads are set for current, and not voltage. Are you talking about a voltage or phase monitor, perhaps?
