petersonra
- Northern illinois
- Semi-retired engineer
I went to start up a project today. I could not get a motor to turn over. I thought the VFD was bad. It was an overhead crane project for a wash line and the traversing motor would not turn over. At first I thought it was the brake but turned out the brake was fine. And I thought maybe I had misconfigured the drive somehow. But no, it turned out to be okay too.
Then the maintenance guy started playing with it when I started up the drive. It would just hum out at the motor a little bit until he gave it a push. Then it would run fine. Even stranger it did not seem to matter which direction he pushed it. The motor would take off in that direction once he got it moving. Eventually we found a loose wire on the motor terminal block and once all three wires were tight on the terminal block it worked fine. Never had that happen before.
