fandi
- Los Angeles
- Electrical Engineer
Hello All,
There are two separate buildings with no common walls:
Building A has 2 residential units (units #1, #2). Building B has 2 residential units (units #3, #4). Currently the main service panel and all the subpanels for the four units are at building A. This means there are currently multiple branch circuits from building A going to unit #3 and #4 of building B.
Now the changes:
- The main service panel is being upgraded with a new location outside building A.
- The subpanels of the four units first were planned to be upgraded but because of section 225.30 (assuming the exceptions of this section can't be used), only units #1 & #2 are upgraded. The subpanels of units #3 & #4 are not being touched so they're grand-fathered in. Only the feeders from the new main service panel to the existing subpanels #3 & #4 are upgraded.
My question: Is 225.30 still violated with the above proposal/changes? (again assuming the project does not qualify to the exceptions of this section).
Thank you.
Now the changes:
Thank you.
