800.2 ... Abandoned Communications Cable. Installed communications cable that is not terminated at both ends at a connector or other equipment and not identified for future use with a tag.
So the key is if you don't want to remove it you just tag it for future use and then it poses no danger.800.3(C) (C) Spread of Fire or Products of Combustion Section 300.21 shall apply. The accessible portion of abandoned communications cables shall not be permitted to remain.
don_resqcapt19 said:So the key is if you don't want to remove it you just tag it for future use and then it poses no danger.
Don
