cdcengineer
So, I was asked if it was ok to abandon a NM / romex cable in the wall if it was disconnected =, capped and labelled but left inside of the panel. I was unsure how to respond as normally if both ends were in a junction box / enclosure than I would be happy. I think if disconnected at both ends and removed from the enclosure(s) and labelled as abandoned that is legit. I have read numerous posts on the forum, but nothing regarding baseboard heat. In this case, the one end will still be inside the panel (but disconnected) and theoretically could be reconnected in the future, whereas the other end is stuffed into the wall because the baseboards have no junction box. Feedback is greatly appreciated. Thx DC
