electric pole
When bonding an above ground swimming pool, do you have to bond every vertical metal column and every location where the metal top rail joins together? Is a certain screw and lug required? If yes, what are they? If you bond the metal deck attached to the pool and it has an attached folding ladder that folds down to the grass do you have send the number 8 wire to the ladder to bond the ladder? If there is any other advice related to the topic that you can share with me I would really appreciate it.
