Above ground pool bonding question.
Rpm90001
New member
Endicott ny
Good morning,
I have the the electrical system done on our new above ground pool, but now just started bonding the pool. My question is with the #8 wire. Do it have to be a continuous 1 section of wire start to finish? I only have a pump and pool to bond, no other metal, lights etc. I would like to go from the lug on my pump around the pool and and end at the 9sq inch plate in the skimmer, then go back to the 4 evenly spaced metal support post and attach a lug to each and attach a 2ft piece to the #8 copper wire I ran around the pool with a direct burial connector. Any help with this will save me some trouble with the inspector. It's Saturday, and my call to him went to voicemail.
Thank you for your help
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
