Above Ground Pool Bonding
jb77k
New User
Chicago
Homeowner
Good morning!
I’m about to install the bonding loop for a metal above ground pool. Everything seems relatively straightforward, it I have a few small questions:
Does the entire loop need to ground to my main service panel inside the house?
I am planning on putting the disconnects on a post with the outlets for the pump and electric heater (an outlet for each and a disconnect for each). First off, does that seem logical/allowable? Second, if the disconnect boxes are metal, do they need to be tied into the bonding loop even if they are more than 5’ away from the pool? I need to put the disconnects near the equipment, because it won’t be possible to see the house based on the location of the equipment, so I can’t locate the disconnects there.
One final thought - if there is a product that would be better for my disconnect setup, please let me know!
Much appreciated for any thoughts!
Please try diychatroom.com
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
