arfrcchic
- Watertown, NY
Been doing some research on electrical installation for an AG pool. Using 20A gfci breaker with 12-2 individual conductors. Sharing the pvc with the convenience outlet. Since the pool pump circuit is gfci at the breaker can I use a standard breaker for the convenience receptacle and install a gfci receptacle? If so would I have to run 2 separate grounds or would 1 ground in the conduit be sufficient?
