New to pool installations just curious about a few items? Why a twist lock for the pump, i find most pump manufacturers provide a standard 5-15P the max only be 3' so that would mean you need a twist lock at the 5' or 6' permieter depending what code you are under, however cutting the cord would void the warranty? why not just a standard 5-20R? also whats up with the eq. bonding requirements it appears you need to create a grid under the pool extending horizontally beyond the pool and connected to the motor grounding lug, if the motor is double insulated than you connect it to the branch circuit equipment ground conductor, and you have to attach a ground from the grid to the vertical metal supports of the pool. wow I hope i understand this now.
