bradleymattlin
- Airville, PA
Good afternoon everybody,
Just did a new install on a new above ground pool with a double insulated pool pump. Obviously no lug on the motor. So did bond ring and attach at four spots and bonded the water. Is this where you stop the bonding? Or does this need to connect to the equipment grounding conductor. I understand 680.26 (b) saying the bonding conductor doesn’t have to go back to a service equipment. Is that because the old style pumps did the connection with the lug???
