Unfortunately you will not likely get an answer that is in agreement with the NEC on this.Originally posted by bill addiss:
Petez,
Your best bet is to ask your local AHJ/Inspectors what they want to see specifically in terms of what, where and how many points they want bonded.
Bill
How Deep?Originally posted by Petez:
What is it necessary to bond on above ground pool?
Why not?Unfortunately you will not likely get an answer that is in agreement with the NEC on this.
I don't understand the question.Originally posted by jwelectric:
How Deep?
I beleive if you follow the NEC in the average instance you would bond the motor, and other metal parts to gether with the pool itself. If the pool itself is metal and the parts are all bolted together you are required to extend the bondng jumper to the pool at one point. In my experience inspectors like to have you run the bonding jumper around the pool and attach to it at multiple locations.Originally posted by bill addiss:
