Re: above ground swimming pool bonding
As far as BONDING this above ground pool, the NEC only requires it in one location. I myself (this is my personal belief) would tend to bond it in more places as the problem of stray voltage in the earth is becoming more prevalent these days. Anyone who lives in high lightning areas should think about this also.
Jim before you start altering the motors to the pool, UL is very, very restrictive as to the requirements of altering any pool pump motors.
Swimming Pool And Spa Equipment (WABX)
There are more than 5 pages of small print requirements of pool equipment.
Here is a little:
PUMPS (WCSX)
Pumps investigated for storable pools are so identified and are additionally marked"DO NOT USE WITH PERMANENTLY INSTALLED POOLS".
Pumps investigated for permanently installed pools are so identified and are additionally marked "DO NOT USE WITH STORABLE POOLS".
The capital lettering is by UL, not me. Quoted from page 114 of the General Information for Electrical Equipment 2003. (the 2004 version does not come out until later this spring)
If you are concerned, and you should be, change the motor to a listed motor.
Pierre
