We are doing an install for an above ground fuel tank with a dispenser (gasoline).
The tank contractor says I need to install a ground rod At the location for the metal frame of the tank.
I cannot find anything in the NEC that requires this, I believe it should be Bonded but I do not see any good reason to drive a rod.
IMO I think the tank guy doesn't understand grounding and bonding, but I may be wrong.
Is this maybe a WI tank code thing maybe??:ashamed1:
