Dpmelectric
- Somers, CT
- Electrician
Hello,
I am wiring an aboveground pool in CT (2020 NEC). The pool structure components are all non-metallic (track, uprights, top plates, base plates) except the pool wall. The pool has a vinyl liner. I ran my #8 bare copper (Perimeter Surfaces) around the perimeter 18-24" out from the wall - 4" below subgrade. I connected the perimeter bond wire to the water bonder mounted in the skimmer, the pump motor, and the pool wall (at the seem of the wall).
The Inspector states that the perimeter bond needs to be connected at (4) spots uniformly around the pool. On previous pools ive done, this is what i would do. But this pool is the first i've come across with no metal components to connect to. To connect in four spots, you would need to drill the pool wall, but the liner is right there.
My question is, is an aboveground pool considered a Non-Conductive Pool Shell and therfore bonding at 4 points shall not be required? As 680.26B(2)
Thanks in advance.
DPM
Thanks in advance.
DPM
