bure961
- Farmingham, MA
We have a 18' aboveground composite pool with a 20amp gfci recept. at pump / motor. Gfci is in wp inuse box / cover. Should this be replaced with a twist lock plug and single recept feed with a gfci at main panel ?
A change will be made to install a water bond in skimmer bonded to lug on pump motor. I am not sure about a equipotental ring around pool since pool has been up for 8-10 years and really not sure where it could be connected to the four points Pool is surrounded with crushed stone some places at 20" and others up to over 4' wide of crushed stone. There is a cyclone Fence about 4' away that borders the pool on 2 sides.
Is there something else to do to make this pool much safer and NEC complient besides from taking it down ?
Thanks for any information given here.
