slick 50
- 6 super bowl ring city
Hello,
I been thinking about this but maybe someone has dealt with similar situation? Lets say you got a food truck that is powered by a 7,500 watt portable generator through a power inlet box. All the AC wiring in the food trailer have EGC's and all metal parts are grounded and bonded together back to the generator through the 4-wire cord. The generator does not have a grounding electrode established and is floating..?
Now, you leave the truck connected to the trailer while in-use and the 12VDC trailer plug is connected between truck and trailer as nobody would disconnect the plug unless they were disconnecting the trailer. All the metal components in the trailer will be factory bonded to the frame of the trailer therefore all the metal components are bonded to the 12VDC negative battery terminal as well as the ground from the 120/240VAC.
If there was a 120VAC short to ground in the food trailer, would that fault current travel to the truck battery and damage the truck's electronics or would it not take that path? I'm thinking it would flow to the truck's battery because there is no grounding electrode system at the generator?
Thank you!
Thank you!
