I thought it'd help
I thought it'd help
300.2 Limitations
(A) Voltage. Wiring methods specified in Chapter 3 shall be used for 600 volts, nominal, or less where not specifically limited in some section of chapter 3.
300.3 (C)(1) Conductors of Different Systems.
(1) 600 Volts, Nominal, of Less. conductors of circuits rated 600 volts, nominal, of less ac circuits and dc circuits shall be permitted to occupy the same equipment wiring enclosures, cable, or raceway. All conductors shall have an insulation rating equal to at least the maximum circuit voltage applied to any conductor within the enclosure, cable, or raceway.
In most cases that is not the case in respects to the respective insulation!
Your lucky, I just typed all this out in another post of today.
