Ac busbar 1600A
jjavier
Maine
Hi
I have problems finding an ac box manufacturer of an ac box with two inputs of 800A (CB) and one output of 1600 A (with two input meters).
When I can find somebody that could do this work?
Could anybody give me advise?
Hi
Just to be clear, you are referring to an AC combiner panel for grid interactive inverters? Otherwise there would be synchronization problems.
And if by "two inputs" you meant two POCO connections, you would have no control over the split of power between the two meters.
I am guessing that the two meters are two production meters? More details please.
If you are talking about a parallel connection on the POCO side of the two meters, the panel would have to be SUSE.
Hi
Why not just use two fused discos and a tap box/bus duct?
Hi
Like GD, I also do not understand what you are trying to do. If you are talking panelboards, as far as I know they do not go above 1200 A, so you would need a switchboard or split it into two or more smaller pieces of equipment.
Ac busbar 1600A
Look at
Sun Valley Electric Mfg LLC
1334 N. 21st Avenue
Phoenix, Arizona 85009
Telephone: (602) 258-6448 Fax: (602) 254-6923
Very PV friendly
http://www.sunvalleyelectricmfg.com/products.htm
"The Can Do Company"
Service Entrance Metering for Your Project -
* Large Residential
* Commercial Single Tenant
* Commercial Multiple Tenant
* Wall Mount 400-800AMP
* Pad Mount Single Meter 400-1000AMP
* Pad Mount Multi Meter 400-1600AMP
* UL Listed & Built to EUSERC Requirements
Hi
Soryy, I didn´t expain well.
Probably I am looking for a switchgear, because we need join two lines of 800Amps in one of 16000Amps. Probably this pad could works.
This is a picture is a better explanation.
Look at
1334 N. 21st Avenue
Very PV friendly
* Large Residential
