A ac cable New member Apr 17, 2010 #1 Is Al ac cable ok to use in a nurcing home, do you have to use steel ac cable? The Al is HCF rated
V Volta Senior Member Location Columbus, Ohio Apr 17, 2010 #2 ac cable said: Is Al ac cable ok to use in a nurcing home, do you have to use steel ac cable? The Al is HCF rated Click to expand... The sheath is permitted to be of aluminum, and used in the Patient Care Areas, as long as it is rated as an Equipment Grounding Conductor with an insulated copper EGC 517.13(A) and (B), such as Southwire's AP or AFC's HCFC. Welcome to the forum.
