Re: AC circuit Breaker Size
Luke I also have had the same thing happen,What gets me is some manufacturers,have some models that go just over what I was always used to.Look at a 5 kw single phase heat strip,by all rights it should be wired in 10/2 nm (residential unit).But some companys now use a larger blower motor that takes it to 32 amps,We have been bitten all to many times by this and now wire all electric A/H/U`s with 6/2 nm.All said after initiating this change we are no longer at risk.
That`s an A/H/U a compressor uses min/max listing and without that there is no possible way to know what to install
